1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: blockingSockTest.cpp Compiling error
To: <[email protected]>
Date: Thu, 10 Jun 2004 14:50:06 +0900
Hello everyone,
When I try to compile R3.14.6 against Tornado2.2/vxWorks5.5, there are 2 errors about
the socket functions, connect() and bind() in blockingSockTest.cpp file.
/epics/Tornado2.2/host/sun4-solaris2/bin/ccppc -c   -D_POSIX_SOURCE       -DCPU=PPC604  -DvxWorks -i
nclude /epics/Tornado2.2/
target/h/vxWorks.h  -ansi  -O3  -Wall     -mcpu=604 -mstrict-align -fno-implicit-templates   -fno-bu
iltin  -I. -I.. -I../../.
../../include/os/vxWorks -I../../../../include       -I/epics/Tornado2.2/target/h
.../blockingSockTest.cpp
.../blockingSockTest.cpp: In method `clientCircuit::clientCircuit(const address &)':
.../blockingSockTest.cpp:130: passing `const sockaddr *' as argument 2 of `connect(int, sockaddr *,
int)' discards qualifiers
.../blockingSockTest.cpp: In method `server::server(const address &)':
.../blockingSockTest.cpp:160: passing `const sockaddr *' as argument 2 of `bind(int, sockaddr *,
.../blockingSockTest.cpp: In function `void blockingSockTest()':
.../blockingSockTest.cpp:210: warning: unused variable `class server srv'
gnumake[3]: *** [blockingSockTest.o] Error 1
gnumake[3]: Leaving directory `/epics/base-3.14.6/src/libCom/test/O.vxWorks-ppc604'
gnumake[2]: *** [install.vxWorks-ppc604] Error 2
gnumake[2]: Leaving directory `/epics/base-3.14.6/src/libCom/test'
gnumake[1]: *** [libCom/test.install] Error 2
gnumake[1]: Leaving directory `/epics/base-3.14.6/src'
gnumake: *** [src.install] Error 2
So should it be like the following?
line 130:
    int status = ::connect (
        this->sock,(struct sockaddr *)  & addrIn.sa, sizeof ( addrIn ) );
line 160:
    int status = bind ( this->sock,
Thank you very much!
Guobao Shen
KEKB Control Group
J-PARC Control Group
RE: blockingSockTest.cpp Compiling error Jeff Hill
Re: blockingSockTest.cpp Compiling error Andrew Johnson
RE: multiple virtual IOCs with single CA server? Jeff Hill
Re: multiple virtual IOCs with single CA server? Dirk Zimoch
Prev: JCA problems-entry point in ca.dll not found daniel funken
Next: RE: blockingSockTest.cpp Compiling error Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: multiple virtual IOCs with single CA server? Dirk Zimoch
