1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Question on transition modules
To: [email protected]
Date: Fri, 4 Jun 2004 15:41:14 -0700
In our group at SLAC we are using some MV167/MV177 and some PPC 2700 VME controllers. Each class has its own transition module. Rumor has it that using the wrong transition module can damage the CPU. Since there seem to be active components on the transition module, this is entirely believable.
We also have some older VME crates with homebrew "transitions"; these crates all currently have MV167/MV177 modules. The interface is entirely passive, with connections to the backplane and to external connectors for one console port and ethernet. The advantage of these crates is that one can actually get modules in without a mallet, and that many are available. The layout of the crate precludes using the commercial 2700 transition module without moving the power supply around.
Before I fry an MV2700, I would like to know if this purely passive "transition" solution has the possibility of actually harming the CPU. Can anyone explain the caveats of these transition issues, please!
Thank you in advance.
/Ron Chestnut
Re: Question on transition modules W. T. Waggoner
Re: Question on transition modules Andrew Johnson
Prev: Re: Bugs in 3.14.5 (recall) Kate Feng
Next: RE: Bugs in 3.14.5 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Base Release 3.14.6 Marty Kraimer
Next: Re: Question on transition modules W. T. Waggoner
