1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time
To: [email protected]
Cc: [email protected]
Date: Fri, 4 Jun 2004 15:09:11 +0200
>>>>> Bernhard Kuner <[email protected]> writes:
  > [...] Why couldn't we have both - as a kind of "value inheritance"?
What about:
 o Allowing $(name=default) in the template database, as the first level
   of default values.
   (-> per template)
 o Allowing a line like
      default{SCAN=Passive, HOPR=9, LOPR=1, ADEL=0.5, MDEL=0.1}
   in the head of a file entry in a substitution file, mutually
   exclusive with the unchanged pattern{} keyword used for tabular
   material - to avoid messy incomprehensive tables.
   The default specifications on this line would override the default
   definitions in the template database.
   (-> per use)
 o Allowing the usual unchanged macro substitutions in the lines of the
   substitution file.
   (-> per instance)
Should fit any of the mentioned cases without implying anything on
anyone, shouldn't it?
Ralph
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Benjamin Franksen
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
Prev: Re: LabVIEW/EPICS Brand Dr. Holger
Next: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
