It was my mistake in the first message. I recognised the "bug" when I was running make and supposed dbLoadTemplate was invoked. Later I saw that the make system uses the msi and a call of dbLoadTemplate produces the warnings. We will therefor be releasing a new version of MSI which behaves like the old dbLoadTemplate program and leaves the unexpanded $(HOPR) and $(LOPR) variables in the output.Yes, but I'm just a user of this make system and never had a look on in that is more deep as neccessyry :-) We are also leaning towards implementing Andreas Luedeke's suggestion of being able to put default values for particular macros inside the template file. If you wish to persue your idea of including defaults in the substitutions file pattern line, you'll have to write your own tool to do that (or modify one of the existing EPICS programs).My Idea of putting defaults in the pattern was spontaneous when I was considering the ability of having defaults by setting all substitutions in the first line of a .substitution file and using the msi's feature to "keep it in mind" for the other lines. Here the way to put it in the pattern line is a cleaner way. The advantage of this is to have "individual" defaults for a special application instead of "global" defaults in the template itself. But I agree that Andreas' idea is also really good to prevent that one has to change all .substitution files when changing the template. Why couldn't we have both - as a kind of "value inheritance"? Regards Bernhard -- ------------------------------------------------------------------- -- [email protected] ----------- Bessy Gmbh ----------------- -- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 - -------------------------------------- 12489 Berlin ---------------
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
