1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time
To: kuner <[email protected]>
Cc: [email protected]
Date: Thu, 03 Jun 2004 16:38:22 -0500
kuner wrote:
Remark: The substittutions $HOPR and $LOPR are used in both files, but in the .substitution files it is forgotten for the second file, test1.template.
After the run of make dbloadTemplat will create:
record(calc,"X:rdbk") {
   field(DESC,"calculation")
   field(SCAN,".5 second")
   field(CALC,"A")
   field(INPA,"X:rd .PP.NMS")
   field(HOPR,"9")
   field(LOPR,"1")
record(ai,"Y:$(SNAME):rd") {
   field(DESC,"position readback")
   field(HOPR,"9")
   field(LOPR,"1")
I am unable to replicate your results using EPICS R3.13.9, R3.13.10 or R3.14.6. These are my source files:
test.substitutions
file test.template {
 { NAME="X", HOPR="9", LOPR="1"}
file test1.template {
 { NAME="Y" }
test.template
record(calc,"$(NAME):rdbk") {
       field(CALC,"A")
       field(INPA,"$(NAME):rd .PP.NMS")
       field(HOPR,"$(HOPR)")
       field(LOPR,"$(LOPR)")
test1.template
 record(ai,"$(NAME):rd") {
These are the messages I get when expanding that substitutions file on the host using dbLoadTemplate:
Inflating database from test.substitutions
<string>: HOPR referenced but undefined
macExpandString failed
<string>: LOPR referenced but undefined
Installing database ../../../db/test.db
rm test.t.db.raw
Unfortunately it does install the test.db file, when it should have aborted the make because of the errors - this is not a bug in dbLoadTemplates, it's a problem with the EPICS build system. However, it did generate warning messages, and the file it actually installed looks like this:
                field(DESC, "calculation")
                field(SCAN, ".5 second")
                field(CALC, "A")
                field(INPA, "X:rd .PP.NMS")
                field(HOPR, "9")
                field(LOPR, "1")}
record(ai,"Y:rd") {
                field(DESC, "position readback")
                field(HOPR, "$(HOPR)")
                field(LOPR, "$(LOPR)")}
i.e. it did not keep the old values for $(HOPR) and $(LOPR), it just didn't replace the macros.
If I use dbLoadRecords on the IOC instead, I get these error messages:
iocexample> dbLoadTemplate "test.substitutions"
IocLogClient: EPICS environment variable "EPICS_IOC_LOG_INET" undefined
iocLogClient: logging disabled
Cannot set field HOPR to $(HOPR)
Cannot set field LOPR to $(LOPR)
filename="../macCore.c" line number=709
Y:rd.HOPR Has unexpanded macro
Y:rd.LOPR Has unexpanded macro
The database after loading looks like this:
iocexample> dbDumpRecord pdbbase, 0, 0
record(ai,"Y:rd") {
        field(DTYP,"Soft Channel")
        field(CALC,"A")
        field(INPA,"X:rd PP NMS")
        field(HOPR,"9")
        field(LOPR,"1")
value = 0 = 0x0
i.e. no value is given to Y:rd.HOPR and Y:rd.LOPR, they remain at their default values.
On R3.14.6, the IOC expansion is even more verbose with error messages:
dbLoadTemplate("test.substitutions")
Error   Last token ")"
input line:      field(HOPR,"$(HOPR)")
   in: path "."  file test1.template line 3
input line:      field(LOPR,"$(LOPR)")
   in: path "."  file test1.template line 4
db_parse returned -1
filename="../../../src/libCom/macLib/macCore.c" line number=734
filename="../dbLexRoutines.c" line number=313
macExpandString failed for file test1.template
filename="../dbLexRoutines.c" line number=942
Bad Field value
Bad Field value
The only way we can replicate your results here is by using msi to do the macro expansion on the host, which gives:
phoebus% msi -S test.substitutions
       field(CALC,"A")
       field(HOPR,"9")
       field(LOPR,"1")
 record(ai,"Y:rd") {
     field(HOPR,"9")
     field(LOPR,"1")
We will therefor be releasing a new version of MSI which behaves like the old dbLoadTemplate program and leaves the unexpanded $(HOPR) and $(LOPR) variables in the output.
Note that the rules for how templates are expanded are found in the IOC application's <top>/config/RULES.Db file. We assume that your RULES.Db has been modified to use msi instead of dbLoadTemplate.
We are also leaning towards implementing Andreas Luedeke's suggestion of being able to put default values for particular macros inside the template file. If you wish to persue your idea of including defaults in the substitutions file pattern line, you'll have to write your own tool to do that (or modify one of the existing EPICS programs).
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Eric Norum
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Ralph Lange
found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
Prev: Re: Bugs in 3.14.5 Eric Norum
Next: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
