It's a little easier to see what you are proposing if you use the diff -c or -u options to provide some context for the changes.
I don't see how this makes any difference. If your static variables aren't getting initialized to 0 there must be something wrong with the board-support package startup code.
I think that the existing behaviour matches the semantics described in the application developer's guide. Here's the code in question: ============================================================ void epicsThreadSleep (double seconds) { rtems_status_code sc; rtems_interval delay; extern double rtemsTicksPerSecond_double; if (seconds <= 0.0) { delay = 0; } else { delay = seconds * rtemsTicksPerSecond_double; if (delay == 0) delay++; } sc = rtems_task_wake_after (delay); if(sc != RTEMS_SUCCESSFUL) errlogPrintf("epicsThreadSleep: %s\n", rtems_status_text (sc)); } ============================================================= The documentation for epicsThreadSleep says, ".... If delay is <= 0 then a delay of 0 is requested of the underlying architecture. What happens is architecture-dependent but often allows other threads of the same priority to run." This is in fact what happens on RTEMS -- rtems_task_wake_after(0) causes a "yield to other tasks at the same priority". -- Eric Norum [email protected] Advanced Photon Source Phone: (630) 252-4793 Argonne National Laboratory
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
