1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: organizing extensions/applications
To: Geoff Savage <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 3 Jun 2004 10:36:38 +0200
Hi Geoff,
In general I would recommend CVS using its import and merging features
to handle such a situation, as you are indeed importing different
releases of different structures from different "vendor"s and apply
local changes and patches that you may want to keep (or not) through the
process of importing a new release.
To stay consistent and comprehensive you will have to use a strict
tagging scheme and follow standard procedures for applying local changes
and importing new vendor releases.
Putting different modules from different vendors under one TOP (like
- in your case - extensions) will always be a bit harder to manage than
keeping them in different TOPs, but it should be possible nevertheless.
There's a document by Andrew located in the 3.13 doc tree called "IOC
SCM Procedures Quick Reference Card" that describes a tagging scheme
along with the procedures for local patches and release imports.
Certainly path names, terms, and structures are APS flavour, but I'm
sure you will be able to get the idea and adopt/adapt it for your case.
We're using that scheme for much of the stuff from other sites (base
itself, certain device supports etc.) and are ... quite happy with
it. It's not dead easy to manage, but the task itself isn't simple, so
the approach seems fair enough.
Hope that helps,
Ralph
>>>>> "Geoff" == Geoff Savage <[email protected]> writes:
  > Hi,
  > One of my current confusions with EPICS is how to organize
  > extension/application software developed here at Fermilab and downloaded
  > from other sites.  I'm wondering how other sites tackle this issue.  Do
  > we need to specify a standard way to package our work for distribution?
  > One particular thing I have noticed is with extensions.  Each extension
  > often includes extensions/Makefile and extensions/src/Makefile.  When I
  > unpack a new extension with these makefiles included I lose any changes
  > I have made to the versions on disk.  This also includes overwriting
  > R3.14 makefiles with R3.13 makefiles.  Comments?
  > Thanks in advance.
  > Geoff
organizing extensions/applications Geoff Savage
Prev: RE: found a bug in 3.13.9 dbLoadTemplate - after all that time J. Frederick Bartlett
Next: PXI & EPICS Al-Adwan Ahed
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: organizing extensions/applications Geoff Savage
