The behaviour of msi is sick, because the expanded .db file will depend
of the order of the lines, the use of the expansion tool
msi/dbLoadTemplate and, neither all writing errors nor forgotten strings
will be recognised.
It would be more usefull to have default values for substitutions that
may be overwritten in the string expansion lines. May be something like
this:
file test.template {
pattern{ NAME, HOPR="9", LOPR="1", MDEL="0.1"}
{ "X", "7", "-1", "0.2"} --> this is the original idea of the pattern
{ "Y" } --> use the defaults
{ "X", LOPR="-1"} --> use the defaults, but not for LOPR
{ HOPR="5"} --> To forget the NAME (no default defined) should cause
an error
regards
-- [email protected] ----------- Bessy Gmbh -----------------
-- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 -
-------------------------------------- 12489 Berlin ---------------
- RE: found a bug in 3.13.9 dbLoadTemplate - after all that time Chestnut, Ronald P.
- Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Tim Mooney
organizing extensions/applications Geoff Savage
<2004>
RE: found a bug in 3.13.9 dbLoadTemplate - after all that time J. Frederick Bartlett
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
