1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: found a bug in 3.13.9 dbLoadTemplate - after all that time
To: "'Marty Kraimer'" <[email protected]>, kuner <[email protected]>
Cc: [email protected]
Date: Wed, 2 Jun 2004 09:14:15 -0700
 I agree with Marty on this. If the alternate behaviour is required (forgetting all previous macro definitions), separate dbLoadTemplate commands can be issued, each with its own "file" set.
/Ron Chestnut
-----Original Message-----
Sent: Wednesday, June 02, 2004 5:23 AM
To: kuner
Subject: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time
First I want to make sure I understand what you are saying.
If a substitution file contains
file test.template {
 { NAME="X", HOPR="9", LOPR="1"}
file test1.template {
 { NAME="Y" }
You are saying that any appearences of $(HOPR) or $(LOPR) in test1.template should NOT be expanded.
Both dbLoadTemplate and msi (Macro Substitution and Include) expand
$(HOPR) and $(LOPR) using the last definition they received. Thus in the above they will be expanded using HOPR="9", LOPR="1"
I can see either semantic definition being valid. Since the existing semantics have been in use for many years, it does not seem to be good idea to make a change. Many users may rely on the existing semantics.
Marty Kraimer
kuner wrote:
> Hi,
> Consider this templates:
> test.template
>  record(calc,"$(NAME):rdbk") {
>        field(DESC,"calculation")
>        field(SCAN,".5 second")
>        field(CALC,"A")
>        field(INPA,"$(NAME):rd .PP.NMS")
>        field(HOPR,"$(HOPR)")
>        field(LOPR,"$(LOPR)")
> test.template
>  record(ai,"$(NAME):$(SNAME):rd") {
>      field(DESC,"position readback")
> and this substitution file:
>  { NAME="Y" }
> Remark: The substittutions $HOPR and $LOPR are used in both files, but
> in the .substitution files it is forgotten for the second file,
> test1.template.
> After the run of make dbloadTemplat will create:
> record(calc,"X:rdbk") {
>    field(CALC,"A")
>    field(INPA,"X:rd .PP.NMS")
>    field(HOPR,"9")
>    field(LOPR,"1")
> record(ai,"Y:$(SNAME):rd") {
>    field(HOPR,"9")
>    field(LOPR,"1")
> HOPR and LOPR will be set in both records, so the last defined value
> from the former substituted file will be used for the actual file.
> This is not correct.
> Grüssle Bernhard
> PS: the work I did when I found this was not such an easy EPICS database.
Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Tim Mooney
Prev: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
Next: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: found a bug in 3.13.9 dbLoadTemplate - after all that time Ralph Lange
