First I want to make sure I understand what you are saying. Yes, because the definition of a value in the first template probably hasn't to do anything with the value of the second one but the name. Every template has to have its own macro expansions. The behavior now avoids an error when the .db will be loaded and sets it to anything. Mistakes like this cause a bad behavior of the database and are not easy to find. Both dbLoadTemplate and msi (Macro Substitution and Include) expand $(HOPR) and $(LOPR) using the last definition they received. Thus in the above they will be expanded using HOPR="9", LOPR="1" krautig, gruselig, bad and evil. I can see either semantic definition being valid. Since the existing semantics have been in use for many years, it does not seem to be good idea to make a change. Many users may rely on the existing semantics. And how many of them are traped by this? You mean a .substitution file like this should work?? file defineAnything.template { { FIRST="1",SECOND="2",THIRD="3",VIERTER="4",FUENFTER="5",SECHSTER="6" } } file takeSomething.template { } file takeSomeOtherThing.template { } file takeItOrLeaveIt.template { } This will expand to... to what? (May be, C-Hardcorepragrammer would like it) best regards Bernahrd Kuner -- ------------------------------------------------------------------- -- [email protected] ----------- Bessy Gmbh ----------------- -- +49 30 6392 4981 ------------------ Albert Einstein Strasse 15 - -------------------------------------- 12489 Berlin ---------------
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
