Subject: |
help building StripTool and caSnooper under EPICS R3.14.6 |
Kevin Tsubota <[email protected]> |
To: |
"tech-talk (E-mail)" <[email protected]> |
Date: |
Mon, 31 May 2004 23:13:10 -1000 |
I've successfully built EPICS R3.14.6 for solaris-sparc-gnu and am
attempting to build caSnooper and StripTool under it. However I've run into
the following error building them:
gmake[4]: Entering directory
`/home/ktsubota/epics/extensions/src/StripTool/O.solaris-sparc-gnu'
g++ -ansi -pedantic -Wtraditional -o StripTool -O3 -Wall
-Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion
-Wstrict-prototypes -Wpointer-arith -Winline -fPIC -D_REENTRANT -DUNIX
-DEXPL_TEMPL -I. -I.. -I/usr/dt/include -I/usr/openwin/include
-I/usr/openwin/include -I/usr/openwin/include -I../../../include/os/solaris
-I../../../include -I/home/ktsubota/epics/base-3.14.6/include/os/solaris
-I/home/ktsubota/epics/base-3.14.6/include -DUSE_MOTIF -DUSE_CLUES
-DUSE_XMU -DSOLARIS=8 -D_POSIX_C_SOURCE=199506L -D__EXTENSIONS__
-L/home/ktsubota/epics/base-3.14.6/lib/solaris-sparc-gnu/ -L/usr/dt/lib/
-L/usr/openwin/lib/ -mt
-R/home/ktsubota/epics/base-3.14.6/lib/solaris-sparc-gnu
-R../../../lib/solaris-sparc-gnu StripHistoryAR+ArR.o StripConfig.o
StripCurve.o Strip.o StripDialog.o StripDataSource.o StripGraph.o
StripMisc.o cColorManager.o ColorDialog.o StripTool.o StripCA.o jlAxis.o
jlLegend.o ComboBox.o FastLabel.o Tabs.o x_rotate.o rotated.o browserHelp.o
LiteClue.o main_c.o getHistory.o -lca -lCom -lXm -lXt -lXmu -lX11
-lsocket -lnsl -lposix4 -lpthread -lCrun -lm
ld: fatal: library -lCrun: not found
ld: fatal: File processing errors. No output written to StripTool
collect2: ld returned 1 exit status
gmake[4]: *** [StripTool] Error 1
Where do I get the Crun library from? I get this error for caSnooper as
well.
Also to get this far for StripTool, I had to specify NO for HAVE_XPM and
USE_SDDS in Makefile.Host.
Is this normal for solaris-sparc-gnu architecture?
Thanks in advance.
Kevin
RE: EtherIP & AB PLC's Rarback, Harvey
found a bug in 3.13.9 dbLoadTemplate - after all that time kuner
<2004>
CVS vulnerability Jeff Hill
<2004>
