1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EtherIP & AB PLC's
To: [email protected]
Date: Fri, 28 May 2004 13:28:50 -0400
Hi All,
  If anyone has any experience with the EtherIP driver, I was wondering
if they have run across the same problem I have described below. I am
using it with a r3.13 release of EPICS, mv177 front-end, HPUX 11
back-end.
  The EtherIP driver is installed and appears to be talking correctly
across the ethernet to an Allen Bradley Logix555 PLC. I am reading and
writing DINT's, but the rather simple operation of writing a "0" to a
BOOL tag does not seem to be working. It's tied to a choice button
through
MEDM (also tried a momentary button, and even a "dbpf" from the command
prompt). On the other hand, it's writes a "1" fine. Has anyone
experienced
this and/or know what the "fix" is?
  On a related note, has anyone thought about expanding the driver to
also talk to program tags? Our engineers are really interested in that
functionality.
  Thanks!
David Wetherholt ([email protected])
Jefferson Lab
Prev: Re: Power Ten power supplies Steven Hartman
Next: CVS vulnerability Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: error in building cdCommands Zheng Lifang
Next: RE: EtherIP & AB PLC's Rarback, Harvey
