On Tue, May 18, 2004 at 04:40:57PM -0500, Robert Soliday wrote:
> Delete epics/base/bin/linux-x86/makeMakefile.pl and
> epics/base/bin/linux-x86/installEpics.pl
> Edit epics/base/configure/CONFIG_SITE and set:
> COMPAT_313=YES
> Next type make from epics/base to setup the the 3.13 compatibility. It
> shouldn't need to rebuild any of the programs in base.
> Now you should be able to build medm without worrying about the perl
> scripts.
> You could also download our Redhat RPM
> EpicsExtensions-3.14.5-1_3.2x.i386.rpm that contains medm.
> http://www.aps.anl.gov/asd/oag/installationGuide_Linux.htm
> --Bob Soliday
Great! This solved my problem. This made MEDM compile out of the box.
And it doesn't crash when I run it now.
Thanks for the fast and excellent help!
-lewis
> J. Lewis Muir wrote:
> > Hello. I'm having problems getting the EPICS MEDM extension to work.
> > medm crashes when I try to run it.
> > Below, I've stated exactly how I've built EPICS and the MEDM extension.
> > These steps were performed on an x86 Red Hat Enterprise Linux (RHEL) WS
> > v.3 computer. I have tried the same steps on an x86 Red Hat Linux 9
> > computer with the same results.
> > The version of gcc is 3.2.3.
> > The version of Open Motif is 2.2.2.
> > The version of XFree86 is 4.3.0.
> > Here are the steps I followed to build EPICS and the MEDM extension.
> > Download needed files:
> > $ cd /data/jlmuir
> > $ mkdir downloads
> > $ cd downloads
> > $ wget http://www.aps.anl.gov/epics/download/base/baseR3.14.5.tar.gz
> > $ wget http://www.aps.anl.gov/epics/download/extensions/\
> > extensionsConfig_20040406.tar.gz
> > $ wget http://www.aps.anl.gov/epics/download/extensions/medm3_0_3.tar.gz
> > $ cd ..
> > Build EPICS Base 3.14.5:
> > $ mkdir opt
> > $ mkdir opt/epics-3.14.5
> > $ cd opt/epics-3.14.5
> > $ tar -xzvf ../../downloads/baseR3.14.5.tar.gz
> > $ mv base-3.14.5/ base
> > $ cd base
> > $ export EPICS_HOST_ARCH=linux-x86
> > $ make clean uninstall
> > $ make
> > $ cd ..
> > Build EPICS MEDM extension:
> > (I've left out the new-style extensionsConfigure_20040406.tar.gz files
> > since MEDM doesn't seem to use them. I've also tried including them but
> > they don't make the crash problem go away.)
> > $ tar -xzvf ../../downloads/extensionsConfig_20040406.tar.gz
> > $ tar -xzvf ../../downloads/medm3_0_3.tar.gz
> > $ cd extensions
> > $ vi config/RELEASE
> > EPICS_BASE=/data/jlmuir/opt/epics-3.14.5/base
> > $ cd src/medm
> > (make fails without doing this first)
> > $ cp ../../../base/configure/tools/makeMakefile.pl \
> > ../../../base/bin/linux-x86/
> > $ cp ../../../base/configure/tools/installEpics.pl \
> > $ make
> > This time it seems to mostly compile but fails when linking medm with a
> > bunch of undefined reference errors like this:
> > cc medm.o -o medm
> > medm.o(.text+0x26a): In function `parseCommandLine':
> > : undefined reference to `medmPrintf'
> > medm.o(.text+0x2d0): In function `parseCommandLine':
> > : undefined reference to `convertNameToFullPath'
> > medm.o(.text+0x45d): In function `parseCommandLine':
> > : undefined reference to `extractStringBetweenColons'
> > The command "cc medm.o -o medm" doesn't look right since it doesn't
> > include any of the libraries that medm needs.
> > So I compile it by hand like this:
> > $ cd medm/O.linux-x86
> > $ cc -o medm *.o -L/usr/X11R6/lib -lX11 -lXt -lXm -lm \
> > -L/data/jlmuir/opt/epics-3.14.5/base/lib/linux-x86 -lca -lCom \
> > ../../xc/O.linux-x86/libANLwidgets.a \
> > ../../printUtils/O.linux-x86/libPrintUtils.a
> > Now I try to run it:
> > $ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/data/jlmuir/opt/\
> > $ ./medm
> > (The first two error messages repeat many times (and the first appears
> > more times than the second) and then it exits after the last error:)
> > Tue May 18 15:39:07 CDT 2004
> > xErrorHandler:
> > BadWindow (invalid Window parameter)
> > xtErrorHandler:
> > No realize class procedure defined
> > Tue May 18 15:39:08 CDT 2004
> > xtErrorHandler:
> > MEDM Version 3.0.3: Loading aliased fonts..
> > SIGSEGV
> > Aborted
> > Does anyone have any suggestions to help me get this working? I'd also
> > be interested in hearing whether anyone has gotten this version of EPICS
> > and MEDM to work on other systems (Linux or otherwise).
> > Thanks!
> > -lewis
- MEDM crashes immediately under Linux J. Lewis Muir
next 3.14 release Geoff Savage
<2004>
<2004>
