1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: building R3.13 extensions with R3.14.5
To: Geoff Savage <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 18 May 2004 17:55:18 +0200
Note that there's also a second variable called
   COMPAT_313
that can be set to YES to allow 3.13 IOC applications to be built.
Btw: All of this is explicitly covered in the 3.14.5 Release Notes, but
I know that such information always has a strong tendency to be in the
one place that you don't look for it.
Cheers,
Ralph
>>>>> "Andy" == Andy Foster <[email protected]> writes:
  > Geoff,
  > I had a problem with "makeMakefile.pl" not being copied to
  > the bin directory.
  > It turned out to be because I hadn't set:
  > COMPAT_TOOLS_313=YES
  > in
  > "base/configure/CONFIG_SITE"
  > This is a change introduced in the configuration files
  > between releases 3.14.4 and 3.14.5.
  > Not sure whether this will solve all of your problems
  > but hope it helps anyway.
  > Cheers,
  > Andy
  > On Fri, 14 May 2004, Geoff Savage wrote:
  >> Hi,
  >> As the subject says I am attempting to build R3.13 extensions with
  >> R3.14.5.  I am following the instructions at
  >> http://www.aps.anl.gov/epics/modules/base/R3-14/5-docs/BuildingR3.13ExtensionsWithR3.14.html
  >> with no success.  Here are the error messages.
  >> [savage@d0ol30 extensions]$ gmake
  >> stat(): No such file or directory at ./config/fullPathName.pl line 6
Re: building R3.13 extensions with R3.14.5 Geoff Savage
Re: building R3.13 extensions with R3.14.5 Andy Foster
Prev: Re: building R3.13 extensions with R3.14.5 Andy Foster
Next: Re: building R3.13 extensions with R3.14.5 Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
