1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: building R3.13 extensions with R3.14.5
To: Geoff Savage <[email protected]>
Cc: [email protected]
Date: Tue, 18 May 2004 16:29:52 +0100 (BST)
Geoff,
I had a problem with "makeMakefile.pl" not being copied to
the bin directory.
It turned out to be because I hadn't set:
COMPAT_TOOLS_313=YES
in
"base/configure/CONFIG_SITE"
This is a change introduced in the configuration files
between releases 3.14.4 and 3.14.5.
Not sure whether this will solve all of your problems
but hope it helps anyway.
Cheers,
Andy
On Fri, 14 May 2004, Geoff Savage wrote:
> Hi,
> As the subject says I am attempting to build R3.13 extensions with
> R3.14.5.  I am following the instructions at
> http://www.aps.anl.gov/epics/modules/base/R3-14/5-docs/BuildingR3.13ExtensionsWithR3.14.html
> with no success.  Here are the error messages.
> [savage@d0ol30 extensions]$ gmake
> stat(): No such file or directory at ./config/fullPathName.pl line 6
> gmake -C configure buildInstall
> gmake[1]: Entering directory
> `/mnt/nobackup/home/savage/extensions/configure'
> gmake -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 buildInstall
> gmake[2]: Entering directory
> `/mnt/nobackup/home/savage/extensions/configure/O.l
> inux-x86'
> gmake[2]: Nothing to be done for `buildInstall'.
> gmake[2]: Leaving directory
> `/mnt/nobackup/home/savage/extensions/configure/O.li
> nux-x86'
> gmake[1]: Leaving directory `/mnt/nobackup/home/savage/extensions/configure'
> gmake -C src buildInstall
> stat(): No such file or directory at ../config/fullPathName.pl line 6
> gmake[1]: Entering directory `/mnt/nobackup/home/savage/extensions/src'
> gmake -C alh buildInstall
> stat(): No such file or directory at ../../config/fullPathName.pl line 6
> gmake[2]: Entering directory `/mnt/nobackup/home/savage/extensions/src/alh'
> perl
> /d0usr/products/epics/NULL/base-3.14.5/bin/linux-x86/makeMakefile.pl O.linu
> x-x86 Host
> Can't open perl script
> "/d0usr/products/epics/NULL/base-3.14.5/bin/linux-x86/mak
> eMakefile.pl": No such file or directory
> gmake[2]: *** [O.linux-x86] Error 2
> gmake[2]: Leaving directory `/mnt/nobackup/home/savage/extensions/src/alh'
> gmake[1]: *** [alh.buildInstall] Error 2
> gmake[1]: Leaving directory `/mnt/nobackup/home/savage/extensions/src'
> gmake: *** [src.buildInstall] Error 2
> [savage@d0ol30 extensions]$ printenv HOST_ARCH
> Linux
> [savage@d0ol30 extensions]$ cat config/RELEASE
> #RELEASE Location of external products
> EPICS_EXTENSIONS=$(TOP)
> #EPICS_BASE=/usr/local/iocapps/R3.13.9/support/base/3-13-9-asd1
> #EPICS_BASE=/usr/local/iocapps/R3.14.5/support/base/3-14-5-asd1
> EPICS_BASE=/d0usr/products/epics/NULL/base-3.14.5
> The file ./config/fullPathName.pl does indeed exists in the extensions
> area.  The makeMakefile.pl was not installed in the base-3.14.5 build.
> Any suggestions?
> I'm going to try and use the makeBaseExt.pl script to create a new
> extensions area.
> Thanks for the support.
> Geoff
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Re: building R3.13 extensions with R3.14.5 Ralph Lange
building R3.13 extensions with R3.14.5 Geoff Savage
Prev: Waveform markers on MEDM Cartesian plots Eric Norum
Next: Re: building R3.13 extensions with R3.14.5 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: building R3.13 extensions with R3.14.5 Geoff Savage
