Hello all.
I tried to replacement old config and configre directoris to last vertions.
The previous my compile problem was config and configure files used old versions.
And I compile gateway2.0 with new configure files under Windows but i found compile errors.
I will be testing to under Linux and Solaris when i return to PLS.
HOST : Win2K
and Visual C 6.0
base 3.14.5
---- error ---
C:\epics\extensions\src\gateway>make
make -C O.win32-x86 -f ../Makefile.Host T_A=win32-x86 BUILD_TYPE=Host install
make[1]: Entering directory `/cygdrive/c/epics/extensions/src/gateway/O.win32-x86'
cl /GX /GR /nologo /D__STDC__=0 /Ox /W3 -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIO
NS /DWIN32 /D_WINDOWS /MD -I. -I.. -I../../../include/os/WIN32 -I../../../include -Ic://epics/base-3.14.5/include/
os/WIN32 -Ic://epics/base-3.14.5/include -c /Tp ../gateAsCa.cc
gateAsCa.cc
../gateAsCa.cc(43) : error C2375: 'connectCB' : redefinition; different linkage
../gateAsCa.cc(38) : see declaration of 'connectCB'
../gateAsCa.cc(66) : error C2375: 'eventCB' : redefinition; different linkage
../gateAsCa.cc(39) : see declaration of 'eventCB'
make[1]: *** [gateAsCa.obj] Error 2
make[1]: Leaving directory `/cygdrive/c/epics/extensions/src/gateway/O.win32-x86'
make: *** [install.win32-x86] Error 2
Kiman,
PLS Control Group.
To: "Tech-Talk"
Subject: Re: gateway2_0_0_0Beta8 compile error.
Date: Wed, 28 Apr 2004 09:39:18 -0500
Kiman,
Based on your output, the base you are using is apparently 3.13
(solarisGnu), and you are getting 3.13.9 headers. Gateway 2.0 requires
3.14.5 or later.
First, set COMPAT_TOOLS_313=YES in base/configure/CONFIG_SITE and then
do a make in base/config/tools to install the necessary Perl scripts. This
is necessary starting with 3.14.5.
Second, set EPICS_BASE to your 3.14.5 base in
extensions/config/RELEASE.
The Gateway should build properly on solaris-sparc, linux-x86, and
win32-x86. I do these three platforms regularly.
-Ken
- RE: gateway2_0_0_0Beta8 compile error Kenneth Evans, Jr.
CapFast Dr. Chong Lee
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
