The record support code still uses Magic Numbers unfortunately. 2. Where is the best place to find a "How to write device support" manual? There is some material in the Device Support lectures from the 2003 USPAS course: http://www.aps.anl.gov/epics/docs/USPAS2003/10_Device_Support.pdf but this doesn't go into the "return 2" issue at all, which is a record-specific but commonly used convention. Once you've got the basics covered by that lecture and you're looking for specifics like that, the information should be found in the Record Reference Manual entry for the record type, or in the record source code. Other device support for the same record type can also be useful. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
