It could be made to work that way - but it doesn't work that way now. I believe that the DOL field is ignored if it is a constant. It seems so from what you've described. Actually Bob, the code says you're wrong there, it probably changed since you wrote it. This is from the AO's init_record routine (R3.13.x, but should be the same in R3.14.x): /* get the initial value if dol is a constant*/ if (pao->dol.type == CONSTANT) { if(recGblInitConstantLink(&pao->dol,DBF_DOUBLE,&pao->val)) pao->udf = FALSE; } However you erre right about it doing the read on initialization, and that gave me the hint to what I think is happening. This code appears lower down in the same routine: status=(*pdset->init_record)(pao); switch(status){ case(0): /* convert */ value = (double)pao->rval + (double)pao->roff; if(pao->aslo!=0.0) value *= pao->aslo; value += pao->aoff; if (pao->linr == menuConvertNO_CONVERSION){ ; /*do nothing*/ }else if (pao->linr == menuConvertLINEAR){ value = value*pao->eslo + pao->eoff; }else{ if(cvtRawToEngBpt(&value,pao->linr,pao->init, (void *)&pao->pbrk,&pao->lbrk)!=0) break; } pao->val = value; pao->udf=FALSE; break; case(2): /* no convert */ break; It looks to me like Pete's device support is returning a 0 from its init_record routine, when it should be returning a 2 as it hasn't properly set the RVAL field. I think that explains the problem and where the correct solution needs to go - in ornlSerial. I'd suggest checking all of its output device supports which I believe should all do the same thing. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
