1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Initialising an ao record from a constant DOL
To: <[email protected]>, <[email protected]>
Date: Wed, 21 Apr 2004 15:34:26 +0900
Dear Pete;
Have you tried to use closed_loop mode with constant DOL such as the
following.
record(ao, "$(device):SETSIZE") {
    field(DESC, "Pump Size")
    field(DTYP, "ornlSerial")
    field(OUT,  "@digitel mpc size p=1 u=$(port) m=$(unit) p1=$(pump)")
    field(PINI, "YES")
    field(DOL,  "100.0")
    field(OMSL, "closed_loop")
    field(EGU,  "l/s")
    field(DRVL, "0.0")
    field(DRVH, "1200.0")
    field(LOPR, "0.0")
    field(HOPR, "1200.0")
    field(PREC, "0")
Kukhee Kim
Instrument & Control, KSTAR
Korea Basic Science Institute
52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
Korea
Email: [email protected]
Tel: +82 42 870 1616     Fax: +82 42 870 1609      Cell: +82 17 513 4849
-----Original Message-----
Sent: Saturday, April 17, 2004 12:11 AM
To: [email protected]
Subject: Initialising an ao record from a constant DOL
I'm trying to initialise an analog output record
by putting a constant in the DOL field (see below).
But the VAL field gets set to zero rather than 100.
The record does process and outputs this zero.
I can work around this by Initialising from another record
using clsed loop mode but it does seem to be a bit of a cludge
(see commented out lines).
What am I doing wrong?
    field(PINI, "YES")
    field(DOL,  "100.0")
#    field(DOL,  "$(device):INITSIZE")
#    field(OMSL, "closed_loop")
    field(EGU,  "l/s")
    field(DRVL, "0.0")
    field(LOPR, "0.0")
    field(PREC, "0")
record(ai, "$(device):INITSIZE") {
    field(VAL, "200.0")
Pete
mailto:[email protected]
phone:+44 (0)1925 603974
fax:    +44 (0)1925 603124
CLRC
Daresbury Laboratory
Keckwick Lane
Warrington
WA4 4AD
UK
Initialising an ao record from a constant DOL Owens, PH (Peter)
Prev: RE: Initialising an ao record from a constant DOL Kim, Kukhee
Next: Re: Initialising an ao record from a constant DOL Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Initialising an ao record from a constant DOL Owens, PH (Peter)
