I have no idea if this is your problem. But I had an identical problem to yours on my mvme2400 boards. I had to edit the file sysDec21x40End.c The line I had was this: static char decParamTemplate[] = "0x%x:0x%x:0x%x:0x%x:-1:-1:-1:0:0x%x"; I changed it to this: static char decParamTemplate[] = "0x%x:0x%x:0x%x:0x%x:-1:-1:-1:0:0x%x:8"; And all of my problems went away. You can easily test this by changing the line and rebuilding vxWorks. But remember, that the first pause will not go away until you make the bootrom and put it into the flash memory. Craig
----------------------------------------------------------- Craig Walther Email: [email protected] Joint Astronomy Centre Phone: (808) 969-6556 660 N. A'ohoku Place Fax: (808) 961-6516 Hilo, Hawaii 96720 USA
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
