1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MVME5110
To: Dirk Zimoch <[email protected]>
Cc: Mark Rivers <[email protected]>, TECHTALK <[email protected]>
Date: Wed, 14 Apr 2004 11:03:59 -0400
Dirk,
    Wow that's fast!   What I am using takes at least eight (8)
minutes minimum to boot.  But, I am using much older KineticSystems
Corporation Model VXI 195-21 chassis's which is Motorola 68000 CPU
based!
    Hope this will make you feel better.
    Also, in my case, the Motorola 68000 CPU is booting from
an old HP 9000/745 host computer across a 10 Mbit network.  The
68000 CPU must transfer its operating system and all files that it
needs to operate from the host HP computer. So,  slow + slow + slow
must equal even slower.
Billy R. Adams
Dirk Zimoch wrote:
Mark Rivers wrote:
Dirk,
when I reboot a Motorola MVME5110, it takes ages (30 sec to be exact) until the vxWorks boot procedure starts. It takes another 30 seconds starting the loaded vxWorks kernel.
Does anyone know what the board is doing in all that time? The MVME2306 have never waited for so long. Can I reduce that time?
I see exactly the same 30 second delays on MVME2700 when they are connected to certain models of Ethernet switches. I believe it is a problem with the 10/100 or full/half duplex negotiation. I have always been able to eliminate the problem by putting an Ethernet hub between those switches and the MVME2700. I believe that Andrew Johnson made changes to the bootrom code and BSP to try to fix the problem, but they did not help.
Mark Rivers
The delay is *before* anything happens on the network:
-> reboot
[30 seconds delay]
Press any key to stop auto-boot...
 0
auto-booting...
[all the boot parameters printed here]
Attached TCP/IP interface to fei0. [no delay here!]
Attaching network interface lo0... done.
Loading... 1461088
Starting at 0x100000...
[30 seconds delay]
Attached TCP/IP interface to fei unit 0 [no delay here!]
The delay also happens when I boot from TFFS (flash file system) with no network connected.
-- Billy Adams <mailto:[email protected]> Sverdrup NASA/Langley ROME Group Assigned to: Research Facilities Branch of Research Facilities Services Competency Building 1251, Room 126D NASA Langley Research Center Hampton, Va. 23681-2199 Phone 1-757-864-6242 Fax 1-757-864-8095
RE: MVME5110 Mark Rivers
Re: MVME5110 Dirk Zimoch
Prev: Re: Bidirectional device support Luedeke Andreas
Next: Re: MVME5110 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: MVME5110 Dirk Zimoch
