If an extension has a Makefile.Host and a Makefile that includes files
from $(TOP)/config it is a R3.13 type extension and you should use the
extensions/config tarfile files. Set EPICS_BASE in the RELEASE file
to your R3.14.5 base. R3.13 type extensions can be built with R3.14 base.
You can have both extensions/configure and extensions/config in the same
extensions top directory. The R3.13 type extensions will use the config
files and extensions that have been converted to R3.14 Makefiles will
use the configure directory files.
Janet
David Decotigny wrote:
Sorry for the previous post again, I did not look at the right doc.
I post the way I made caex compile here, I hope it is the "right" way:
- cd anywhere
- "<EPICS_BASE>/bin/linux-x86/makeBasext.pl -b <EPICS_BASE>" to
generate a template
- untar caex in the src/ directory
- rename src/caex/Makefile.Host as Makefile, and customize the 2
includes (inspired from the simpleExt and exampleExt templates):
include $(TOP)/configure/CONFIG
include $(TOP)/configure/RULES
- update the DIRS variable in src/Makefile
Is it the general way to do the things correctly ?
BTW, http://ics-web1.sns.ornl.gov/edm/ seems to be down right now.
Sincerely,
- Extensions configuration/compilation David Decotigny
- Re: Extensions configuration/compilation David Decotigny
RE: Bidirectional device support Liyu, Andrei
RE: Bidirectional device support Thompson, David H.
<2004>
Re: Extensions configuration/compilation Robert Soliday
MVME5110 Dirk Zimoch
<2004>
