1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Extensions configuration/compilation
To: [email protected]
Date: Tue, 13 Apr 2004 14:59:20 +0200
Sorry for the previous post again, I did not look at the right doc.
I post the way I made caex compile here, I hope it is the "right" way:
- cd anywhere
- "<EPICS_BASE>/bin/linux-x86/makeBasext.pl -b <EPICS_BASE>" to generate a template
- untar caex in the src/ directory
- rename src/caex/Makefile.Host as Makefile, and customize the 2 includes (inspired from the simpleExt and exampleExt templates):
include $(TOP)/configure/CONFIG
include $(TOP)/configure/RULES
- update the DIRS variable in src/Makefile
Is it the general way to do the things correctly ?
BTW, http://ics-web1.sns.ornl.gov/edm/ seems to be down right now.
Sincerely,
David Decotigny -- LLR/info -- Bureau 04 1012D -- poste 4404
Re: Extensions configuration/compilation Robert Soliday
Re: Extensions configuration/compilation Janet Anderson
Extensions configuration/compilation David Decotigny
Prev: Extensions configuration/compilation David Decotigny
Next: Re: Bidirectional device support Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Extensions configuration/compilation Robert Soliday
