Hi, I am new to Epics, and I do have a question that will sound stupid to you all I guess. Sorry for it in advance. I successfully compiled epics 3.14.5 on our host (linux RH9, EPICS_HOST_ARCH set to linux-x86). And now comes the time when I try to compile some "standard" host extension prior to eventually upgrade another extension we use. So I downloaded the extensionsConfigure tarball (20040406), unpacked it, changed the EPICS_BASE variable in extensions/configure/RELEASE to point to our epics' base. Then I decided to compile the "caex" extension, to see how to compile a standard extension. So I downloaded it, untarred it (all is put in extensions/src/caex), and there, I can see the extensions/src/caex/Makefile contains: TOP = ../../ include $(TOP)/config/CONFIG_EXTENSIONS include $(TOP)/config/RULES_ARCHS "make" of course could not find any of these inclusions. Apparently the CONFIG_EXTENSIONS file came with the "extensions" tarball, so the TOP variable seems almost right: I simply renamed "config" as "configure" in the 1st include. But the RULES_ARCH does not sit in the same directory: it might refer to <EPICS_BASE>/configure/RULES_ARCH I guess. So, in the end, the Makefile looks like: TOP = ../../ include $(TOP)/configure/CONFIG_EXTENSIONS MY_EPICS=/home/ddecotig/download/src/epics-base-3.14.5 include $(MY_EPICS)/configure/RULES_ARCHS And, obviously this is not completely correct, for a "make" will be infinitely recursive: [...] make[434]: Entre dans le répertoire `/tmp/epics/extensions/src/caex/O.linux-x86/O.linux-x86' make -f ../Makefile TOP=../..//.. T_A=linux-x86 install make[435]: Entre dans le répertoire `/tmp/epics/extensions/src/caex/O.linux-x86/O.linux-x86' make -f ../Makefile TOP=../..//.. T_A=linux-x86 install make[436]: Entre dans le répertoire `/tmp/epics/extensions/src/caex/O.linux-x86/O.linux-x86' [...] I then noticed another RULES_ARCH file in <EPICS_BASE>/config/ directory, and, if I choose that one instead of the one in <EPICS_BASE>/configure/, I get: [pollindd] epics/extensions/src/caex >make make: *** No rule to make target `install.linux-x86', needed by `install.cross'. Stop. zsh: exit 2 make So I'm sure I missed something, but what ? Perhaps I did not look at the right documentation ? Could someone tell what are the recommended steps to configure/compile an extension ? Would you advise to choose another simple extension to get used to the extensions configuration/compilation process ? Sorry for this. Thanks a lot in avance, -- David Decotigny -- LLR/info -- Bureau 04 1012D -- poste 4404
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
