1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem starting StripTool
To: "'JaSeong Ju'" <[email protected]>, <[email protected]>
Cc: "Ken Evans" <[email protected]>
Date: Mon, 12 Apr 2004 10:24:46 -0600
Hello,
There are know issues with strip tool and EPICS R3.14.5 which don't exist
with EPICS R3.14.4 (see bug reports in Mantis). However, it initially
appears that the symptoms of your problem (failure to connect) do not match
well with the known issues documented in Mantis, and you mention that other
client side tools (ca_test etc) also do not connect properly. Please see the
trouble shooting section in a recent CA reference manual. After following
those steps, if you are still having troubles then feel free to send email
and I will see if I can make further suggestions.
Jeff
> -----Original Message-----
> From: JaSeong Ju [mailto:[email protected]]
> Sent: Friday, April 09, 2004 12:24 AM
> To: [email protected]
> Subject: Problem starting StripTool
> Greetings,
> I installed the ioc example as described in manual and succeded
> in starting it as shown:
> $../../bin/linux-x86/myexample st.cmd
> epics> dbl
> juHost:aiExample
> juHost:aiExample1
> juHost:aiExample2
> juHost:aiExample3
> juHost:calcExample
> juHost:calcExample1
> juHost:calcExample2
> juHost:calcExample3
> juHost:compressExample
> juHost:subExample
> juHost:xxxExample
> epics>
> What I'm trying to do now is to start Striptool. After Striptool
> starts, I put the PV name into the upper window and connect.  Then
> open the graph window.  The plot is empty.
> It looks like PV name is not connected to StripTool.
> When I issue command
> $caget juHost:aiExample
> Channel connect timed out: 'juHost:aiExample' not found.
> $ca_test juHost:aiExample
> Not Found juHost:aiExample
> How do I fix this?
> Thanks.
Problem starting StripTool JaSeong Ju
Prev: RE: Bidirectional device support Purcell, J. David
Next: RE: Bidirectional device support Tang, Johnny Y.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Problem starting StripTool JaSeong Ju
Next: RE: Bidirectional device support Thompson, David H.
