1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Bidirectional device support
Cc: <[email protected]>
Date: Fri, 9 Apr 2004 14:49:39 -0600 (MDT)
Andrew,
Does that mean the value transmitted via a caput() action is
discarded if the target record had PACT true due to being
in its "read" mode, for example, caused to process by a FLNK from
another record?
- Peregrine
On Fri, 9 Apr 2004, Andrew Johnson wrote:
> The talk of how to implement bidirectional I/O through existing record
> types still has a fundamental problem that *cannot* be solved using a
> single VAL field no matter how you implement it - you're going to throw
> away information somewhere if a new output demand occurs at about the same
> time as a new value comes back from the device.  You cannot simultaneously
> hold both a record's last output demand and the value read back from the
> device, unless this record provides the only possible way to change that
> output.  There is no substitute for having two different places to store
> the last demand and the readback information.
Peregrine M. McGehee	Department of Astronomy
New Mexico State University, Las Cruces, New Mexico
Bidirectional device support Andrew Johnson
Prev: Bidirectional device support Andrew Johnson
Next: Re: EPICS Meeting Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Record processing knowledge of dbAccess context Marty Kraimer
