Peregrine McGehee wrote:
As you pointed out, the use of PUTF does not afford a
general solution and that this is only valid for a specific
combination of record linkages and CA client actions:
1. the record must be scan Passive.
2. the "write" action must be triggered by a dbPut to a field
with Process Passive set.
This should say dbPutField, i.e. a put from outside database access.
PUTF is not set if processing occured because an output DB_LINK caused
dbProcess to be called.
3. the "read" action must be triggered by a FLNK.
Is the latter condition equivalent to someone calling dbProcess()
directly?
This sounds correct. But be careful when calling calling dbProcess. In
particular don't call it if you are running under a scan task. When not
part of a scan task it must be surrounded by dbScanLock/dbScanUnlock.
Marty
- Bidirectional device support Andrew Johnson
- Re: Record processing knowledge of dbAccess context Peregrine McGehee
RE: Record processing knowledge of dbAccess context Thompson, David H.
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
