1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Record processing knowledge of dbAccess context
To: [email protected]
Cc: Marty Kraimer <[email protected]>, [email protected]
Date: Thu, 08 Apr 2004 13:20:15 -0600
In which case a possible solution for a bidirectional record
(without custom record types but with custom device support) is:
record A : input record with custom dev sup, scan PASSIVE
record B : periodically scanned record, with FLNK to A
within A's read_xxx device support function:
     if PUTF true then
	grab VAL and write to hardware
     else
	read from hardware and write to VAL
This writes on demand from the CA client and reads periodically.
- Peregrine
J. Frederick Bartlett wrote:
Marty,
  I am somewhat confused by your answer to Peregrine. I had thought the PUTF
field of a record, which is described in the "Record Reference Manual" as
"Did dbPutField cause the current record processing", is exactly what
Peregrine is looking for.
Peregrine M. McGehee	Sloan Digital Sky Survey
LANL/LANSCE-8 and NMSU/Department of Astronomy
(505) 667-3273;	MS H820, LANL, Los Alamos, NM 87545
Re: Record processing knowledge of dbAccess context Marty Kraimer
RE: Record processing knowledge of dbAccess context J. Frederick Bartlett
Prev: RE: Record processing knowledge of dbAccess context J. Frederick Bartlett
Next: Re: Record processing knowledge of dbAccess context Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
