1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Buffer problems
To: "Kevin M. Peterson" <[email protected]>, <[email protected]>
Date: Tue, 6 Apr 2004 11:58:29 -0500
Kevin,
I suspect you are seeing the same problem we have seen at Brookhaven.
You can try to reproduce this problem by sending lots of large ping
packets quickly to the IOC.
Here's how I've done it on Mac OSX.
> ping -s1500 -l3000 <ioc>
On Linux I think the command is the same.  Note that you must be root to
do this.
With this command I have managed to irreversibly hang MVME2700 CPUs, so
that they needed to be rebooted.  This happens something like 10-30% of
the time that the ping command is issued.  Other times it causes long
"delays", where the IOC is not capable of network activity, but then it
recovers in 30 seconds or so.
On MVME172 processors I have only managed to induce that latter
behavior, i.e. delays, but not complete hangups requiring reboot.  But I
have not done extensive tests of this.
Re: Buffer problems Ronald L. Sluiter
Prev: RE: Buffer problems Kevin M. Peterson
Next: Re: Buffer problems Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
