Subject: |
Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) |
Eric Bjorklund <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Fri, 26 Mar 2004 13:10:28 -0700 |
Umm... I may be completely missing the boat here, but didn't the
VME-MXI-1 problem mostly involve bad data returned because of "address
rot" during the READ cycles? (c.f. Eric Norum's clarification post from
14 Nov. 2003).
We've seen a similar problem with one of our boards here at LANSCE. In
our case, the "pipelined" address was not generated by the executing
code. I don't think it was from a PPC or PCI bus "pre-fetch" either,
as there was no read cycle generated for the new address. So unless
there is some real cleverness going on between the Universe and the PCI
controllers, it looks like the Universe chip is just trying to
anticipate the next address I am going to want and putting out on the
bus early (the new address was the logical successor to the addresses I
had previously requested). I am not aware of any cure for this --
except that in our case it is our own board, so we can fix the problem
at that level.
-Eric Bj.
On Mar 26, 2004, at 11:38 AM, Kate Feng wrote:
Kate Feng wrote:
I agree with you that one should enable the posted write by default.
However, it could be disabled, which means the address
pipelining on the UniverseII could be disabled as well on the
Mvme5500.
I thought the origianl issue is "to disable the address pipelinig".
It looks like you have a reason to disable the posted write
for the NI VME-MXI-1. The trad off is to sacrifice the bandwidth
of the VME bus. However, I do not know if the decrease is
significant for your application. I hope this helps.
I ran a short test, which showed a decrease of 33% in
performance for the posted-write disabled mode. It might not be worse
than the VMEchip2 that was used on the MVME167, which is in
your existing system. I do not have the datasheet for the
VMEchip2. I guess it does not provide address pipeling,
which explained why it worked fine with the MXI-1.
Again, hoping this helps. -- Kate
Eric Bjorklund
Los Alamos Neutron Scattering Center (LANSCE)
phone: 505-667-6031
email: [email protected]
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Eric Norum
- mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Kate Feng
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Kate Feng
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Andrew Johnson
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Kate Feng
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Andrew Johnson
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Kate Feng
Job opening at APS John Maclean
RE: Buffer problems Mark Rivers
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
