1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Tornado 2.2.1
To: john sinclair <[email protected]>
Cc: tech talk <[email protected]>
Date: Wed, 17 Mar 2004 13:30:21 -0600
John,
Have you removed -nostdinc from the EPICS configuration file <base>/config/CONFIG.Vx
as documented below?
http://www.aps.anl.gov/epics/modules/base/tornado.php
Ron
john sinclair wrote:
I just built R3.13.9 on tornado 2.2.1 (VxWorks 5.5.1).
Some of the old device support doesn't build (looks like the serial driver interface has changed) and when I boot an IOC and attempt remote access I get
../iocinf.c: bad UDP msg from orib30:5064
on the client side.
Any suggestions?
Re: Tornado 2.2.1 Andrew Johnson
Tornado 2.2.1 john sinclair
Prev: RE: Tornado 2.2.1 Jeff Hill
Next: Re: Tornado 2.2.1 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
