1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Aai pv not returning all values in SNL
To: "'Russ Berg'" <[email protected]>, [email protected]
Date: Mon, 8 Mar 2004 16:15:51 -0800
Russ,
You have, I assume, done something like:
double array_name[100]; assign array_name to "pv_name";
pvGet(array_name);
Right?
/Ron Chestnut
-----Original Message-----
Sent: Monday, March 08, 2004 2:27 PM
To: [email protected]
Subject: Aai pv not returning all values in SNL
Hi, I recently tried to read an aai pv from SNL either via a monitor or a straight pvGet.
When I call pvGet (or process on a efTestAndClear() flag) the first value in the array looks
good but all of the rest of the values are 0.
If I test the pv by running caget from the command line I receive all 100 double values as expected,
I am confused why there would be a difference in the SNL behaviour. I have made sure that the FTVL and NELM fields are set properly, I may have missed something in the documentation though.
Anyone seen this before? Thanks
-Russ
Prev: LabVIEW and EPICS Willem Blokland
Next: RE: [Fwd: LabView/EPICS] Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Aai pv not returning all values in SNL Russ Berg
Next: LabVIEW and EPICS Willem Blokland
