On 2004.03.08 02:24, Kiman Ha wrote:
> Hello! Kay and Stephanie,
> Last Feb, I asked about AB SLC5/05 processor for Ethernet TCP/IP EPICS
> driver and support.
> The AB Comapny people said SLS5/05 PLC processor support EtherNet/IP.
Yes, it might support the common portion of the EtherNet/IP
protocol, the part that's documented at www.odva.org.
That will allow you to read the serial number of your SLC5/05's
ethernet interface.
In addition, you need the CIP service codes that are specific
to your PLC, the ones that allow you to read/write tags
or files or whatever the data of interest is called on the
respective architecture.
> I known your alread developed EtherNet/IP drivers and support for SNS
> project.
That EtherNet/IP driver package uses the CIP codes for the
AB ControlLogix 5000 series as described in
AB Publication 1756-RM005A-EN-E.
The latter publication also lists SCL commands,
but they are very different from the CIP service codes
for the ControlLogix series.
Control Logix uses CIP service codes
0x4C : read data
0x4D : write data
0x0A : multi request
and all those adress string tags on the Logix5000.
As far as I know, the SCL5 doesn't have string tags
but uses file/element/subelement addressing.
So I'm afraid those AB people who talked to you can
recite "EtherIP" from some SLC5 brochure but don't
really understand the protocol.
This means that the ether-ip driver for the ControlLogix 5000 won't
talk to the SLC5, and making it talk to the SLC5 would be a major deal,
close to starting from scratch.
- Re: EtherNet/IP for AB SLC5/05 PLC. john sinclair
- EtherNet/IP for AB SLC5/05 PLC. Kiman Ha
[Fwd: LabView/EPICS] Ned Arnold
Re: [Fwd: LabView/EPICS] Brian Tieman
<2004>
<2004>
