1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: SDDSepics compile problem with 3.14.5
To: "Ernest L. Williams Jr." <[email protected]>
Cc: <[email protected]>
Date: Sun, 7 Mar 2004 21:01:20 -0600
This fixed my problem.  Thanks Ernest.
John Hammonds
Data Acquisition Systems Manager
Intense Pulsed Neutron Source
[email protected]
(630)252-5317
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:[email protected]]
> Sent: Sunday, March 07, 2004 7:02 AM
> To: Hammonds, John P.
> Cc: [email protected]
> Subject: Re: SDDSepics compile problem with 3.14.5
> Hi,
> Be sure to do a make in the <EXTENSIONS_TOP>/configure directory, then
> all should be well.
> This happens because the <EXTENSIONS_TOP> level Makefile is probably
not
> set-up to descend into the configure directory automatically.
> Thanks,
> Ernest
> On Sun, 2004-03-07 at 00:02, Hammonds, John P. wrote:
> > I am trying to build EPICS Extensions and have run into the
following
> > error in the SDDSepics directory.  I can get past this by manually
> > adding the path to the $(EPICS_BASE)/include and
> > $(EPICS_BASE)/include/os/Linux to the gcc command in the O.linux-x86
> > directory but have to do this for a few more files.  I cannot seem
to
> > find the correct place to add the path to get this to compile from
> > makefiles.
> > make[3]: Entering directory
> > `/net/iocapps/R3.14.5/extensions/IPNS1-
> 0/src/SDDSepics/runcontrol/O.linux-x86'
> > /usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> > -D_XOPEN_SOURCE=500  -DOSITHREAD_USE_DEFAULT_STACK      -D_X86_
> > -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall
> > -fPIC -I. -I.. -I../../../../include/os/Linux
> > -I../../../../include         ..../libruncontrol.c
> > ../libruncontrol.c:130:20: tsDefs.h: No such file or directory
> > ../libruncontrol.c:131:19: cadef.h: No such file or directory
> > In file included from ..../libruncontrol.c:133:
> > ../libruncontrol.h:74:19: alarm.h: No such file or directory
> > ../libruncontrol.h:81: syntax error before "chid"
> > ../libruncontrol.h:81: warning: no semicolon at end of struct or
union
> > ../libruncontrol.h:83: syntax error before "pv_user_chid"
> > ../libruncontrol.h:83: warning: type defaults to `int' in
declaration
> > of `pv_user_chid'
> > ../libruncontrol.h:83: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:85: syntax error before "pv_host_chid"
> > ../libruncontrol.h:85: warning: type defaults to `int' in
declaration
> > of `pv_host_chid'
> > ../libruncontrol.h:85: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:87: syntax error before "pv_pid_chid"
> > ../libruncontrol.h:87: warning: type defaults to `int' in
declaration
> > of `pv_pid_chid'
> > ../libruncontrol.h:87: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:89: syntax error before "pv_sem_chid"
> > ../libruncontrol.h:89: warning: type defaults to `int' in
declaration
> > of `pv_sem_chid'
> > ../libruncontrol.h:89: warning: data definition has no type or
storage
> > class
> > ../libruncontrol.h:91: syntax error before "pv_desc_chid"
> > ../libruncontrol.h:91: warning: type defaults to `int' in
declaration
> > of `pv_desc_chid'
> > After I get past this set of errors I get another one:
> 0/src/SDDSepics/logDaemon/O.linux-x86'
> > /usr/bin/g++ -o logDaemon  -L../../../../lib/linux-x86/ -L./
> > -L/net/iocapps/R3.14.5/base/IPNS1-0/lib/linux-x86/
> > -Wl,-rpath,/net/iocapps/R3.14.5/base/IPNS1-0/lib/linux-x86
> > logDaemon.o    -lLogD -lmdbcommon -lSDDS1 -lrpnlib -lnamelist
-lmdblib
> > -lCom -lz
> > /usr/bin/ld: warning: libmatlib.so, needed by
> > ../../../../lib/linux-x86//libmdbcommon.so, not found (try using
> > -rpath or -rpath-link)
> > /usr/bin/ld: warning: libfftpack.so, needed by
> > /usr/bin/ld: warning: libmdbmth.so, needed by
> > ../../../../lib/linux-x86//libmdbcommon.so: undefined reference to
> > `mat_scmul'
> > ../../../../lib/linux-x86//librpnlib.so: undefined reference to
> > `random_2'
> > `mat_trans'
> > `dbesk0'
> > `mat_invert'
> > `K_cei'
> > `gammaQ'
> > `realFFT2'
> > `betaInc'
> > `gauss_rn_lim'
> > `dbesi1'
> > `p_materror'
> > `dbesk1'
> > `mat_zero'
> > `rSigLevel'
> > `E_cei'
> > `dbesi0'
> > Any clues.
> > I am using SDDS 1.26 and SDDSepics 1.26 and Redhat Enterprise Linux
> > 3.0.
> > John Hammonds
> > [email protected]
> > (630)252-5317
> Ernest L. Williams Jr. <[email protected]>
Prev: gtr1-2 for SIS3301 DMA error. Kiman Ha
Next: EtherNet/IP for AB SLC5/05 PLC. Kiman Ha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: SDDSepics compile problem with 3.14.5 Ernest L. Williams Jr.
Next: gtr1-2 for SIS3301 DMA error. Kiman Ha
