1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem of NORD field in waveform (R3.14.4)
To: "Kim, Kukhee" <[email protected]>
Cc: [email protected], "'Chestnut, Ronald P.'" <[email protected]>, "'Bob Dalesio'" <[email protected]>, [email protected]
Date: Thu, 26 Feb 2004 07:24:01 -0600
The waveform record support implements put_array_info as follows (note how it handles nord):
static long put_array_info(paddr,nNew)
struct dbAddr *paddr;
long nNew;
struct waveformRecord *pwf=(struct waveformRecord *)paddr->precord;
   pwf->nord = nNew;
   if(pwf->nord > pwf->nelm) pwf->nord = pwf->nelm;
   return(0);
If you call dbPut instead of writing directly to the waveform record dbPut will call put_array_info.
If you really want to write directly to the array in a record do the following:
1) MAKE sure the link is a DB_LINK.
2)  Get the value of DBADDR *pdbAddr
3) Check the following:
    pdbAddr->dbr_field_type is the type you expect, e.g. DBF_DOUBLE
    long max_elements = pdbAddr->no_elements;
    struct rset *prset = pdbAddr->precord->rset;
   if(!prset->get_array_info || !prset->put_array_info) ERROR
4) Write the array as follows:
   long  n, no_elements,offset
status = prset->get_array_info(pdbAddr,&no_elements,&offset)
if(!status) error Make sure n< max_elements
double *pto = pdbAddr->pfield;
for(i=0; i<n; i++) *pto++ = *pfrom++;
status = prset->put_array_info(pdbAddr,n);
if(!status)error
This will work as long as the array is not a circular buffer. If it does then life gets more complicated.
Kim, Kukhee wrote:
Dear ALL;
I am playing with waveform record on the R3.14.4.  A subroutine record puts values to a waveform record directly, but whole reading values of the waveform were always â0â when I tried âcagetâ.  So, I checked out the NORD field in the waveform record. It was always â0â.  I guess, it is supposed to have same value with NELM field.
So, I made small cheating as the following.  It is a part of subroutine record to set NORD field to same value with NELM field.
ãããã
	DBADDR *pdbAddrLinkA = dbGetPdbAddrFromLink(&prec->inpa);
ããããDBADDR *pdbAddrLinkB = dbGetPdbAddrFromLink(&prec->inpb);
	long   no_elements   = pdbAddrLinkA->no_elements;
ããããwaveformRecord  *precord;
ããããprecord = (waveformRecord*)pdbAddrLinkA->precord;
ããããprecord->nord=no_elements; ããããprecord = (waveformRecord*)pdbAddrLinkB->precord;
And then, I can read waveform normally.
I would like to know, what cause this problem?
Thank you.
Kukhee Kim
Instrument & Control, KSTAR
Korea Basic Science Institute
52 Yeoeun-dong, Yusung-gu, Daejeon 305-333
Korea
Email: [email protected]
Tel: +82 42 870 1616     Fax: +82 42 870 1609      Cell: +82 17 513 484
ã
Problem of NORD field in waveform (R3.14.4) Kim, Kukhee
Prev: Problem of NORD field in waveform (R3.14.4) Kim, Kukhee
Next: Lx ioc-shell chrashes Frank Hoeft
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
