1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA conversion problem
To: Eric Boucher <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Thu, 19 Feb 2004 13:42:24 -0600
Eric Boucher wrote:
Hi Folks,
I've a problem when requesting DBR_CTRL_XXX types with channel access.
If I request a DBR_CTRL_FLOAT and that one of the limit (Upper display,
Lower display, etc...) is 0 then instead of getting 0 and
get -1.17549435E-38.
If I request any other DBR_CTRL_XXX types then I get the correct value.
Is it a bug in the CA convertion routine?
Yes it is a bug.
Amazing. This must have existed since about 1991. It will be fixed in the next 3.13 and 3.14 releases.
The bug is in db_access.c which converts between old and new database access.
Marty
CA conversion problem Eric Boucher
Prev: CA conversion problem Eric Boucher
Next: JCA2.1.1 has been released. Eric Boucher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
