Hi Ben.
Benjamin Franksen wrote:
Hello,
I have a simple question regarding the CA client library: which is the
guaranteed live span of the data ointed to by the void pointer argument
received by a CA event handler routine?
Don't know if I understand you correctly - do you mean the 'dbr' field of
the event_handler_args structure (which itself is passed by value)?
If you do, then after browsing the source for 2min, it seems to me that
what you get is a pointer to a message buffer which is very probably
volatile, i.e. it would surprise me if it would be safe to use it after
the callback returns.
These are just my 2 cents - someone with deeper knowledge might have
to correct me...
-- Till
More specifically: does this pointer change from call(-back) to call(-back) or
does it always refer to the same memory location? (It could of course be
anything in between).
The reason I ask is that (1) i'd like to know if there are any conditions
under which it is safe to store the pointer for later access and (2) i
couldn't find any hint on this in the CA reference manual.
Ben
- CA question Benjamin Franksen
How is it that IOC process only 11000 records per second at AMD Duron 850MHz? Tatiana V. Salikova
<2004>
RE: CA question Jeff Hill
<2004>
