g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: Possible bug in registerRecordDeviceDriver.pl
To: tech-talk@aps.anl.gov
Date: Fri, 23 Jan 2004 09:17:39 -0500
I get the following error loading a library file on vxWorks/Epics 3.14.4:
cd timingbin
value = 0 = 0x0
ld<timingLib.munch
Undefined symbol: p (binding 1 type 0)  <<<<<<<<<<<<<<<<<<<<<
value = 28536800 = 0x1b36fe0
cd timing
value = 0 = 0x0
dbLoadDatabase("dbd/timing.dbd",0,0)
value = 0 = 0x0
timing_registerRecordDeviceDriver(pdbbase)
program
Exception current instruction address: 0x01b47334
Machine Status Register: 0x0008b030
Condition Register: 0x44200082
Task: 0x1b51b18 "tShell"
In timing.dbd I have:
driver (drvV124S)
device (ai,       VME_IO,   devAiV124S,      "Timing Gate")
#registrar("timingSubs") <<<<<<<<<<<<<<<<<<<<< Commented out
And from that   registerRecordDeviceDriver.pl  generates:
epicsShareExtern void (*p)(void);   <<<<<<<<<<<<<<<<<<<<<<<<
int timing_registerRecordDeviceDriver(DBBASE *pbase)
    int i;
    for(i=0; i< 11;  i++ ) {
        if(registryDeviceSupportFind(deviceSupportNames[i])) continue;
        if(!registryDeviceSupportAdd(deviceSupportNames[i],devsl[i])) {
            errlogPrintf("registryDeviceSupportAdd failed %s\n",
                deviceSupportNames[i]);
            continue;
    for(i=0; i< 1;  i++ ) {
        if(registryDriverSupportFind(driverSupportNames[i])) continue;
        if(!registryDriverSupportAdd(driverSupportNames[i],drvsl[i])) {
            errlogPrintf("registryDriverSupportAdd failed %s\n",
                driverSupportNames[i]);
            continue;
    (*p)();   <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    return(0);
The call to (*p)() generates the bus error and the unresolved link error.
The registrar line was commented out since I hadn’t actually completed the registrar function for that source file.  Apparently some pass that registerRecordDeviceDriver.pl made on the dbd file counted the line has having a registrar spec but didn’t pick up its argument.  The work around is to misspell “registrar”.
Re: Possible bug in registerRecordDeviceDriver.pl Kay-Uwe Kasemir
Prev: RE: ? initHookRegister() Liyu, Andrei
Next: Addendum to previous messgge: Possible bug in registerRecordDeviceDriver.pl Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013
Next: Re: Possible bug in registerRecordDeviceDriver.pl Kay-Uwe Kasemir
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
