Thank you very much.
I have small question according 2. Why should static object be?
I tried in Windows:
//Server.h
class CServer{
extern CServer * pCServer;
//Server.cpp
CServer oCServer;
CServer * pCServer = & oCServer;
It works too.
Andrei.
-----Original Message-----
Sent: Monday, January 19, 2004 8:50 AM
To: Liyu, Andrei
Cc: [email protected]
Subject: Re: ? initHookRegister()
Liyu, Andrei wrote:
> Hi,
> If I like to do some job during IOC initialization I should call
> initHookRegister(). But I couldn't understand where (how) can I call
> this function before iocInit()?
I can think of three ways.
1) Call your routine from the st.cmd file
Assume you have a function
int initMyHook(void)
return(initHookFunction(myHookFunction));
the st.cmd file contains
initMyHook
iocInit
2) Use a C++ static object.
class initMyHook {
public:
initMyHook() {initHookFunction(myHookFunction);}
static initMyHook initMyHookObj;
The constructor initMyHook will get called for initMyHookObj at load
time.
3) For 3.14.4 or later use the registrar facility
In your xxxInclude.dbd file the following must appear
registrar(myHook)
Your source file contains
static void myHook(void)
static int firstTime = 1;
if(!firstTime) return;
firstTime=0;
epicsExportRegistrar(myHook);
For 3.14.4 and later method 3) is the recommended method.
> Can anybody write couple words about IOC deinitialization? Has
> Epics similar hook here?
Sorry but iocCore is currently written to run forever. There is no
deinitialization.
> Thanks, Andrei.
- RE: ? initHookRegister() Ralph Lange
Re: ? initHookRegister() Ralph Lange
<2004>
<2004>
