1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: PV reconnect logic question
To: "'Jeff Hill'" <[email protected]>, "'tech-talk (E-mail)'" <[email protected]>
Date: Mon, 12 Jan 2004 09:03:57 -1000
Hi Jeff,
Here are my Sol-8 IOC environment variables:
epics> coreRelease
###  EPICS IOC CORE built on Jan  9 2003
###  EPICS R3.14.1 $R3-14-1$ $2002/12/12 15:56:59$
epics>
epics> epicsPrtEnvParams
EPICS_AR_PORT: 7002
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_ADDR_LIST: 128.171.95.50 128.171.95.171 128.171.136.30
128.171.136.98
EPICS_CA_AUTO_ADDR_LIST: YES
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_MAX_ARRAY_BYTES: 16384
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CMD_PROTO_PORT is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_INET: 128.171.97.52
EPICS_IOC_LOG_PORT: 7004
EPICS_TIMEZONE: CUS::360:040602:102602
EPICS_TS_NTP_INET is undefined
epics>
According to the R3.14 CA Ref Man, section Server Beacons:
If EPICS_CAS_BEACON_ADDR_LIST is not defined,
EPICS_CA_ADDR_LIST is defined, and
EPICS_CAS_INTF_ADDR_LIST is not defined,
then the conents of EPICS_CA_ADDR_LIST will be used to augment the list.
It looks like me setup meets this criteria yet I don't see the server
beason.
Is it because my EPICS_CAS_BEACON_PERIOD is not defined and not defaulting
to the default 15s?
I am running casw but the only time I saw a beacon anomoly whas when I
started
up caSnooper.  I'll explicitly set my EPICS_CAS_BEACON_PERIOD but was
wondering
why I get no beacon anomolies.
-----Original Message-----
Sent: Monday, January 12, 2004 5:41 AM
To: Kevin Tsubota; 'tech-talk (E-mail)'
Kevin,
Your Solaris-8 IOC (acting as a client) probably does not see the server's
beacons because they are addressed to subnet on which your client IOC is not
listening. The EPICS R3.14 CA reference manual explains this situation in
more detail than in past versions of the manual. See the section entitled
"Dynamic Changes in the CA Client Library Search Interval".
It may be that a simple solution will be to expand the server's beacon
address list so that beacons are broadcasted also on your Solaris-8 IOC's
subnet. Alternatively, you could install a CA gateway providing transparent
connectivity for remote clients.
Jeff
> From: Kevin Tsubota [mailto:[email protected]]
> Sent: Friday, January 09, 2004 6:02 PM
> To: tech-talk (E-mail)
> Subject: PV reconnect logic question
> Hi,
> I have EPICS R3.14.1 IOC running on Solaris-8 and it connects to EPICS
> R3.13.0b12 PVs running
> under VxWorks.  As an interim safety measure I disconnect the routes
> between
> the two IOCs at
> night and reconnect them during the day.
> However when I reestablish the routes, my R3.14 IOC PV never reconnects
> to
> the VxWorks PVs.
> It stays in STAT=LINK, SEVR=INVALID state.  THe R3.14 PV is using a CPP
> input link to the
> VxWOrks PV.  When I restart my R31.4 IOC it connects up right away.
> Why doesn't the R3.14 PV reconnect automatically?
> Is there a way to force the R3.14 PV to reconnect without having to
> restart
> it?
> Mahalo!
> Kevin Tsubota
> W.M. Keck Observatory
RE: PV reconnect logic question Jeff Hill
Prev: Re: compile error of EPICS 3.14.4 under windows Janet Anderson
Next: RE: PV reconnect logic question Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: PV reconnect logic question Jeff Hill
