A couple of weeks ago I reported:
> I'm having some problems building EPICS 3.14 stuff on
> solaris-sparc-gnu. I have built base 3.14.4 with no
> problems. I have also built the EPICS example application,
> including the snc example, and the soft IOC works OK.
> The problems I'm having are:
> - An error linking the mpf2-4 test programs. A C++ routine
> (Tcp::connect) which should definitely exist in the libmpf.so
> library is not being found at link time.
This problem is now fixed by upgrading gcc from 2.95.3 to 3.3.2.
> - I have built the 3.14 versions of the extensions ezca,
> EzcaScan and ezcaIDL with no problems. However, when I try
> to use the resulting ezcaIDL.so from IDL on Solaris to do
> channel access it gives a bus error and crashes.
This problem was solved by setting LD_LIBRARY_PATH to point to the new extensions library. It was (mistakenly) pointing to the old extensions library directory.
Thanks to Tim Graber, Marty Kraimer, Andrew Johnson and Ben-Chin Cha in solving this.
cross-compiling base3.14.0alpha2 error Zhao Zhuo
Re: cross-compiling base3.14.0alpha2 error Ralph Lange
<2003>
RE: Problems with solaris-sparc-gnu Mark Rivers
[Fwd: Re: Tornado 2.2, cross-compiling woes] Marty Kraimer
<2003>
