Subject: |
newport mm4000 motor record hardware(gpib/serial) needs |
Zhijian Yin <[email protected]> |
To: |
TECHTALK <[email protected]> |
Date: |
Fri, 12 Dec 2003 12:50:21 -0500 |
What's the hardware requirements for Newport MM4000/3000 to work under
motor record? Currently we have mm3000/4000 work with SPEC/gpib (pci
card under linux). We'd like to have a VME gpib or serial card and put
MM4000/3000 in motor record.
My question is: What kind of VME gpib/serial card should I get? We have
vxWorks 5.3 (BSP mvme-2304, ppc604) and I was able to built epics3.13.9
on it (using the Linux cross compiler from sns).
From motor record (motor4-7-4) src, it seems it needs mpf-gpib (which
supports SBS IP-488) or mpf-serial (SBS OctalUART serial IP module).
But then Mark Rivers MM4000 site
(http://cars9.uchicago.edu/software/epics/dev_mm4000.html) says it also
works with NI-1014.
Can some one who has used it provide some detail on the hardware it needs?
Thanks!
Zhijian Yin
NSLS, [email protected]
RE: Spurious link alarms generated? J. Frederick Bartlett
RE: newport mm4000 motor record hardware(gpib/serial) needs Mark Rivers
<2003>
Re: Insertion Devices Control and EPICS Allan Honey
<2003>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
