I'm trying to prepare a proposal for ID control system at Diamond. During that time I have been asking some people some questions how this is currently managed in EPICS. To my surprise I found out that there was no clear way to solve this problem. I had a discussion with Tim Mooney and we were thinking of some possible solutions for the biggest problem - synchronous motor movement under EPICS. We have developed some suggestions, but I think it is time to broaden the discussion to tech-talk. There may be more people interested in such solutions and there are probably some people with some experience on the matter. First let me remind everyone on the problem. We have two (or more) motors which we would like to move synchronously. This means to guarantee the movement will start and end at the same time. This is extremely important when changing the gap of an insertion device. One may suggest that we should just wire the signal lines together (hardware solution) and use one signal line to control multiple motors, but we also want to move these motors independently. We may implement some logic (using FPGA or some other programmable logic) to multiplex this one signal line in one operation mode and use multiple signals for different motors in some other mode. The OMS VME58 card, which is normally used in EPICS for motion control, supports such synchronized moves, but this is (to my knowledge and experience) not supported via EPICS motor record and device support. We should also provide some kind of sync record, which would take control of correspondent motor records (when instructed to do so) and would then perform the synchronized moves. Needless to say, there are a lot of design choices to identify and make on the behaviour of this record. This mail is intended to identify people who have common interest for such a development in EPICS community. Definitely, we will have to make some modifications to the existing motor software if we decide to go through with any of these ideas. The idea is to make a general EPICS solution for such situations. Cheers, Rok
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
