1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Spurious link alarms generated?
To: tech-talk <[email protected]>
Cc: "Bartlett, Fritz" <[email protected]>
Date: Thu, 11 Dec 2003 18:18:30 -0600
  I have encountered a situation in which spurious (i.e. unexpected) link
alarms are being generated following the reboot of an IOC. The record
connectivity is:
	Record A has a scan rate of one second
	Record A has a forward link to record B
	Record B has an input link in its INP field that references record A with
"NPP"
	and "MS" specified.
When record A is processed for the first time, record B registers an
"INVALID" alarm severity with a "LINK" alarm status. The second time that A
is processed, the "INVALID" alarm severity is cleared.
  I believe that, when record B retrieves the value from record A during the
initial process cycle, the alarm severity that is propagated by the "MS"
specification is "INVALID" because record A must, somehow, retain the
original "INVALID" severity and the "UDF" status even though it has already
processed. During subsequent process cycles, record B does not generate an
"LINK" alarm status because record A no longer has "UDF" alarm status.
  This behavior is counter-intuitive. The "Application Developer's Guide"
states that the forward link is not executed until the originating record
has completed processing. If this is the case, why does an input link to
that record transfer the prior (or initial) alarm state?
  Finally, we are still using release 3.13.4.
											Fritz
Re: Spurious link alarms generated? Marty Kraimer
Prev: RE: Novice EPICS questions re yet another port David Kelly
Next: Software listing Ian Lenzen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: "assert (this->exitWait ( DBL_MAX ))" failed Jeff Hill
Next: Re: Spurious link alarms generated? Marty Kraimer
