1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: aiRecord, RVAL vs. VAL
To: "Amy Baum" <[email protected]>
Cc: <[email protected]>
Date: Thu, 4 Dec 2003 16:30:38 -0600
> But this question still remains:
> Amy Baum wrote:
> >> Why is RVAL only an int type if it is intended to hold the
> >> raw data from hardware?
It is intended for devices like A/D converters that typically return 12,
14 or 16 bit integers of "RAW" values.  These values can be converted to
engineering units by the ai record if the appropriate conversion is
requested.
I agree that having the RAW field be an integer is a limitation.  For
example, I might want to read a voltage from a digital multimeter, which
returns a floating point number, but then have that number converted to
some other units, for example pressure, by the ai record conversion
routine.  As it stands I think device support would have to do that
conversion directly, it could not write into the RVAL field and ask the
record to do the conversion.
Re: aiRecord, RVAL vs. VAL Brian McAllister
Prev: Re: aiRecord, RVAL vs. VAL Amy Baum
Next: Re: aiRecord, RVAL vs. VAL Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
