1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: dynamical record loading/unloading and normal database
To: "'Andrew Johnson'" <[email protected]>, "'Liyu, Andrei'" <[email protected]>
Cc: <[email protected]>
Date: Thu, 4 Dec 2003 13:53:18 -0700
> There might also need to be changes made to the
> Channel Access protocol to implement record deletion.
Both the R3.14 and the R3.13 CA client libraries properly respond to the
server initiated channel delete notification protocol. If an earlier
revision of the CA client library is connected the portable server library
disconnects the client's circuit and assumes that the client will reconnect
as necessary.
Jeff
Re: dynamical record loading/unloading and normal database Andrew Johnson
Prev: Re: process function of record waveform and CA (caput, caget) Marty Kraimer
Next: aiRecord, RVAL vs. VAL Amy Baum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: dynamical record loading/unloading and normal database Andrew Johnson
