1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS to WAGO PLC using Ethernet MODBUS
To: "Elder Matias" <[email protected]>, <[email protected]>, <[email protected]>
Cc: <[email protected]>, [email protected]
Date: Sat, 22 Nov 2003 05:27:19 -0700
If I could add my two cents..... it is also our experience that the Modbus protocol is the most common bus protocol. Whatever driver is used should have the ability to only send requests for those blocks that are requested by the database, include lots of diagnostic information regarding the state of health of the communication, write outputs to the remote I/O promptly, and be able to read values that were set from a different master.
Is this something that we should cover in the next EPICS meeting?
Bob
On Fri, 21 Nov 2003 20:59:39 -0600
 "Elder Matias" <[email protected]> wrote:
John/Eric,
We are willing to provide you with a copy of our version. At CLS we run
most of our IOC software under either RTEMS or Linux. In this
particular case the driver is written for RTEMS and has primarily been
used to talk to MODICON Momentum PLCs and a few other related
applications, such as power meters from PML. We are also willing to
look at merging in changes you may have made.
If there is wider interest I can have the driver and design note tossed
onto an ftp site.
Elder Matias
Canadian Light Source
University of Saskatchewan
John Maclean <[email protected]> Subject: Re: EPICS to WAGO PLC using Ethernet MODBUS From: Eric Williams <[email protected]> Date: Fri, 21 Nov 2003 10:10:32 -0800 Cc: [email protected] In-reply-to: <[email protected]> References: <[email protected]>
<[email protected]> User-agent: Mozilla/5.0 (Windows; U; Windows NT 5.0; en-US; rv:1.4.1)
Gecko/20031008
John,
Can you please email me with a place where I can get this?
I think the EPICS community should settle on one of these to concentrate
their efforts on. I've been doing a survey of PLCs with Ethernet field
bus capability, and MODBUS over TCP/IP is the most common protocol in
the market.
Eric Williams
Advanced Light Source
Lawrence Berkeley Lab
John Maclean wrote:
I have Ethernet-MODBUS support which is based on code obtained from the
Canadian Light Source. The CLS code is written to run on RTEMS and
supports Modicon PLCs.
I modified it to be OS independent, to work with 3.14.2 and to add
support for Siemens power meters.
John.
Vladis Korobov wrote:
Hi all,
I have to connect from EPICS to WAGO System PLC using MODBUS protocol
(via Ethernet).
Has anybody any software for such kind of communication?
Any suggestions and advise will be appreciated, ----------- Vladislav Korobov MKS-2 Group, DESY Notkestr. 85 22607 Hamburg, Germany tel. +49 40 8998 3947 e-mail:[email protected] or [email protected]
Bob Dalesio [email protected] 410 557 0297 Maryland 505 667 5643 Los Alamos (New Number) 505 699 1632 Cell Phone 505 667 6087 Our Secretary (Lisa Marie)
Re: EPICS to WAGO PLC using Ethernet MODBUS John Maclean
Re: EPICS to WAGO PLC using Ethernet MODBUS Elder Matias
Prev: Re: EPICS to WAGO PLC using Ethernet MODBUS Bob Dalesio
Next: Re: Linux -> PPC cross-compile of the Motor Record Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS to WAGO PLC using Ethernet MODBUS Rolf Keitel
Next: Re: EPICS to WAGO PLC using Ethernet MODBUS John Maclean
