1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: close_record ?
To: [email protected]
Date: Tue, 18 Nov 2003 17:42:37 -0800
Noboru Yamamoto wrote:
> Amy Baum wrote:
>> Hi -
>> Is there a routine that epics will call when a record
>> is destroyed? I've been through the developer's guide
>> and can't find anything. I'd like to close some file
>> handles that were opened when init_record() was called.
>> Thanks!
>> Amy
> As far as I understand, a record stays alive as far as IOC is running.
> I don't think there is a method to delete a record from a running database on IOC.
> Or do you need a special operation on the filehandler before robooting IOC?
> Regards,
> Noboru
I'm wondering about a routine that gets called when the IOC is
exiting - when the record is destroyed.
Amy
Re: close_record ? Andrew Johnson
Prev: close_record ? Amy Baum
Next: Re: close_record ? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
