G'day, As I recall RTLinux is a small real-time kernel that also runs the regular Linux kernel as a low priority RTLinux thread. Since an integral part of EPICS is Channel Access it is hard to see how an IOC could be run using only RTLinux threads. Once the 2.6 kernel is available, linux will have much better real time characteristics. My guess is that, with more work needed on base/src/libCom/osi/(posix and/or linux), linux will be sufficient for most EPICS IOC applications. For applications with harder real time requirements at least two other approaches are available. Both require that the real time requirements are localized to a small part of the application. If the entire application has hard real-time requirements than perhaps EPICS is the wrong solution. On method is to use RTLinux or RTAI for the hard real-time and write EPICS device/driver support that communicates with the RTLinux or RTAI threads. Another approach is becoming available. I/O boards are becoming available that include easily programmable FPGAs and high performance Digital and Analog I/O. The FPGAs can be programmed to handle the hard real-time and again EPICS device/driver support can be created to communicate with the FPGA code. Just my thoughts. Marty Kraimer
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
