Hi Andrew,
There are 2 bugs in the .stt rule in base/config/RULES.Host.
Note RULES.Host is used when building code to run on the host, not on a
vxWorks IOC. The more intriguing question is why there's a rule for
.stt files in RULES.Host at all, since there was a very long gap between
about Base R3.10 or earlier and R3.14 when SNL programs could only run
on vxWorks.
I wondered about that a little later, too. My 2nd mail seems to be lost
in space, though. The same buggy rule appears in RULES.Unix, too. As
unused as in RULES.Host, I guess. I also found that RULES.Vx had been
fixed meanwhile.
I stumbled over that while installing R3.13.9 when I did a grep for all
hacks we had applied to R3.13.2. I was astonished that I still could
find the same lines here.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax +41 56 310 4413
- bug in RULES.Host R3.13.* Dirk Zimoch
- Re: bug in RULES.Host R3.13.* Andrew Johnson
Re: Among the things for which I wish... Noboru Yamamoto
<2003>
Compiling SDDS on Linux with R3.14.4 Hammonds, John P.
<2003>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
